AMMO DAWG
- Aug 3, 2012
- 227
Finally got my 2004 Mercruiser 4.3 back in the boat after getting a front timing cover leak resolved and as I was aligning the engine I noticed if I aligned it and rotated the engine it would be way out of alignment. After messing with it for hours I put a 1" pipe in the coupler and cranked it over (see attached). Seems the coupler might be bent or crooked, have you ever seen an issue with a coupler like this? The engine was just rebuilt, had put it in and it leaked at the timing cover so I pulled it again, bought an OEM cover and new oil pan gasket and put it back in. I'm hoping I can just lift the engine and move it forward to get to the bellhousing and coupler versus pulling the engine. Any suggestions on checking the coupler after I pull it, thanks in advance.
