4.3 GL-D carbureted.
krazykatz911
What is the best way to get RV antifreeze through the whole block without issues of getting thermostat to open?
i have been using the 5 gallon Jug of rv antifreeze using earmuffs but it always seems I end up overheating the impeller. Couple of times the impeller housing got red hot. Ughhh.
I always run rv antifreeze through and then drain the block plugs, intake and exhaust manifolds and then store.
thanks in advance
first, you drain the block, heads, exhaust manifold, raw water hose, large J hose and the thermostat cross over on the intake like the manual states
then if you want to add antifreeze, you use a funnel and pour antifreeze into the thermostat housing like the manual states
you need to drain first to get the water and crud out prior to adding antifreeze
