Scott06
- Apr 20, 2014
- 6,934
Long time Mercruiser owner/shade tree mechanic, helping a close friend with his 2002 Glaston 185 that has a 4.3GL & SX sterndrive.
Boat appears to have classic symptoms of needing carb rebuild - rough idle and stumble of transition, some surging when on plane. Fuel filter clean, he went through did cap rotor, plugs and wires last year as the coil wire was coming out of the distributor cap repeatedly.
I have done a lot of carb rebuilds over the years so not concerned about general how -to but this will be my first Holley. It has a 2 bbl carb number 75006-1, which I believe is a 2300 series.
Is there anyone who can tell me or direct me to OEM Volvo specs for -
Float level
initial idle mix settings ( is it the typical 1.5-2 turns out?)
any other carb specs needed?
Having never done a Holley (lots of Mercarbs, Rochester 2 jets, Edlebrock & Carter AFB's) are there any special tools I need for the rebuild? Anything to pay attention to unique to Holley's?
Typically I soak my carbs in berrymans or similar in an ultrasonic cleaner, but that strips the paint off which I was hopeing to leave on as it is a factory untouched carb in decent shape. Does anyone have cleaner recommendations that will leave the paint on?
Also it has a Delco Est ignition - can anyone confirm the initial timing in base mode and total advance ? Wasn't sure if it was the same as for Merc at 8 initial and 24 total. I thought when not in base mode at idle should be 12-15 BTDC?
I think his thermostat is stuck open which is probably not helping the idle. I didn't have my IR gun when I was looking at it this weekend but the two hoses coming of the thermostat housing to the manifolds never get warm. I'm assuming these should be passing hot water after a good WOT run like I did this weekend?
Thanks
Float level
Thanks
