4.3 how to remove thermostat/sleeve from housing
ShoalSurvivor
While flushing on muffs, I noticed my temp rising and falling based on RPM. It's usually very stable, so I decided to remove and test the thermostat. Housing was removed without issue, but the sleeve and thermostat are stuck. I can't remember if these slid in and out easily when I replaced them 10+ years ago.
Do I need to pry? how? suggestions?
I don't want to damage them just to test.
thank you,
2000-ish Mercruiser 4.3L 225hp 4bbl Quicksilver repower SN: 90004747 (#807736R11 / 03252004)
Carter AFB-4.3L-Marine-Electric Remanufactured 4 Barrel Carburator
Alpha 1 Gen II - Transom: 0L517680 Drive: 0L192679 1.62 R (1.81R scratched on top) original drive may have been SN: L40356
ShoalSurvivor
I realized I did this about 10 years ago and found all the deets in my message history.
I've ordered replacements and will wrench it out carefully, since a new sleve comes with the kit.
thanks.
Ayuh,.... Those sleeves tend to rust/ corrode in, so good thing you got a new one coming,....
Some of those sleeves are plastic, some are copper (fabricated)
Scott06
thank you,
Had to typically pry them out with screw driver, so do t come out without breaking them. If you go through the work to get in there dont just test it just replace no sense screwing around
