4.3 L audible alarm
Tafflad
I have a 4.3L mercruiser (carb) model 0W617149 yr 2007
It has low Hrs and has full annual service ... and runs like a dream.
When you put ignition key 'on' prior to starting the Audible Alarm sounds.
Yesterday after evening skiing .. as we were slowly going back to dock ... the Audible Alarm beeped once (1/2 a sec) then quiet, all gauges .. particularly water temp, oil pressure & charging all show OK.
As we were driving it onto trailer the alarm started sounding - continuously, as this was at same time as tilting up drive .. thought it could be related, anyway left it at that.
Got home .. usual run on muffs to flush, and the alarm again staying on continuously ........ oil pressure, water temp & charging all OK.
There are no oil leaks .. levels all OK.
Any suggestions .... or do I need to book this in.
FishHog
Re: 4.3 L audible alarm
so it will sound for 3 different things. High Temp, Low Oil, low gear lube.
If it isn't any of those things (and you verified all of your levels visually), then it is either a faulty sensor or an electrical issue.
