4.3 l carb and intake manifold problem
sumdood
I just finished installing a 4bbl Edelbrock 1409 carb with the Edelbrock performer manifold. the engine is an 89 V6 4.3 liter, it previously had the Mercarb. I also replaced the distributor.
the installation went well, and I replaced the distributor with the rotor facing the same way it did before I started the job.
Now, the engine will only start up when I push the throttle forward so the accelerator pump shoots some gas in the carb, the engine runs at high RPM and than quits. I know that the fuel pump is working as I had to fix a fuel leak. I do not think I have any vacuum leaks. I can keep the engine running briefly by pumping the throttle, it will go around 2000- 3000 RPM for about 10 sec and than die. I can not get it to idle or run at low throttle.
It appears to be not getting fuel through the carb, but I don't think that is the problem as the engine will only run at high throttle and then briefly. Any ideas?
Mark
Tail_Gunner
Re: 4.3 l carb and intake manifold problem
EDL-2111 or 2114 and have you installed true vortec heads?
sumdood
it is a 2111 manifold and a non-vortec engine
Ayuh,... drakorosus,.. Sumdood hasn't been back since april,+ Probably won't be....
It also sounds like Sumdood ain't much of a Mechanic either....
If Your talents are as good, or Better,...
It's a pretty easy straight forward Swap....
What you should do is start a thread of your Own, about whatever Your motor, drive,+ boat is,...
Not Sumdood's...
You'll get Better advice, because it's about Your motor....
Welcome Aboard,+ Good Luck....
