Hi everyone. I have a problem that I need some help with. I had the boat out and was towing the kids on a tube. I took a sharp turn and when we straightened out the boat seemed to have less power. When I throttled down the engine quit and would not turn over at all any more. When I lifted the engine cover it seemed to be ticking and popping like it was over heated. This is what I did to try and check what could be wrong.
1. Checked cooling lines and all had water coming out of drain plugs.
2. Checked engine oil and no water present in oil.
3. Removed spark plugs and serpentine belt and the engine turned over very very slowly.
4. Checked battery voltage and it was fine.
Thanks in advance any and all help from you guys out there would be greatly appreciated it was our first trip on the water this year.
