Larry Baloun
- Jul 28, 2017
- 34
Serial # 1a312851
It seems like I have tried everything possible to resolve my problem and no change.
Under about 3000 rpm - it runs at about 170 degrees - no alarm. Over 3000 it goes up to about 180 degrees and the alarm comes on intermittently. I know it is the hot alarm because if I detach the wire on the thermostat housing the alarm stops.
I have: 1) changed the heat sensor
2) changed the impeller (which was in good shape)
3) changed the thermostat ...all with Mercruiser parts.
Two question: 1) should it alarm at just 180 degrees - if not, how do I get it to stop
2) If 180 degrees is too hot ...how do I get it to run cooler ...it has always been in fresh water.
