I am replacing my 4.3lx block and with a newer block without the mechanical fuel pump. Wired my oil pressure switch and new carter fuel pump. But what to do with the fail safe tube off the Quadra jet carb? Just let it hang or block it off? It’s the tube that use to run to the mechanical pump in case a diaphragm failed.
