I have a 97 Chaparral with a 4.3 LX Gen + that I inherited so I am relatively new to boating on anything other than a canoe . I ran it out on a local lake right before we were expecting to hit freezing temps ( I live in Colorado). The boat ran out fine, but when I decided to freeze-proof it, I realized I was in over my head a bit. I pulled it out of the water, drained the exhaust manifolds and the block via the plugs then took the thermostat housing apart, filled the entire unit with 5 gallons of RV/Marine antifreeze with rust inhibitor ( I replaced all the freeze-plugs) . The entire block was filled as well as the exhaust jackets. The antifreeze ran out the outdrive and I lowered the outdrive to the lowest point possible. Did I miss anything? As for the thermostat - my plan was to remove it so I could cycle the antifreeze through the engine via the "earmuffs", but I could not remove the thermostat. It appears to be in a plastic housing that would break if I forced the thermostat out of the housing. Is there something I am missing? My apologies for the drawn-out description. I will be brief in the future.
