4.3 Merc with surging issues
QUESTBLDR
I bought a 1996 Bayliner with a 4.3 Merc. The engine idles fine, but when under load, it tends to surge part of the time, then run fine, then start surging again. I know the fuel is likely old, because the boat set for a while. Could it also be the spark plugs? Boat is in like new condition...really, and only has this issue. I don't know anything about the Merc's, so looking for a little assistance from the experts.
Re: 4.3 Merc with surging issues
Ayuh,... I would be looking at the Fuel Delivery system,... Probably the Carb....
But,...
It's always a Good Idea to do a Tune Up if you don't know it's history...
TBarCYa
I had the same problem with my 3.0L my first time out this season and when I pulled the plugs expecting to see that it was running lean (fuel delivery problem) I found that the insulator on one plug was damaged and I suspect that this is the cause. Due to the weather, I won't know for sure until next weekend if my problem is solved.
QUESTBLDR
I have not attempted to change the plugs since they are such a bear to get to. That will be my first attempt to fix the problem. I do start the engine and run during the winter, so it doesn't sit for long periods. I would think if a carb problem, it would not run good part of the time. I'll take it in somewhere if I can't figure it out. Thanks
180shabah
Sounds like it is time to catch up on some maintainin'...
Full tune up, and fuel system check.
