Jgrimm1983
- Sep 18, 2020
- 12
New to boating. Bought a 1996 regal 182 last week took it out once and had to be towed back.
Model - MCM 4.3 LX Gen+
Engine Serial - 0F823523
2 barrel carb
First time out everything started fine but after anchoring for an hour boat would not turn over. Ended up replacing starter.
Now after 3 pumps turns over fine and fires right away but will not run. Maybe runs for 1/2 second but nothing. Seems like not getting gas and also cannot hear fuel pump prime when turn key on. After researching some I thought it was fuel pump. Removed it and put 12volts to it and pumped fine so put it back in. Next I went to oil pressure switch removed both wires and jumped the purple wire to purple and yellow wire with a jumper wire (as instructed by another forum to rule out pressure switch) and pump would not pump. The solid purple wire has constant 12 volts to it with key on but when jumped to p/y wire nothing. I then jumped from battery to p/y wire and pump turns on. I am not an electrician by any means but just cannot understand why using the 12volt purple wire is any different from jumping from battery?
Seems weird to have 2 problems at the exact same time and I have read the starter has something to do with fuel pump. So maybe thinking I was given the wrong starter or possibly hooked it up wrong but I took pics and 99.9% sure all wires are in correct spot or at least the spot they came off old starter. Starter I was given from dealership was a Sierra 18-5913-1.
Any help would be appreciated
2 barrel carb
