Hi all, I need help knowing where to look! I had a total lose of power yesterday. was cruising along then slowly lost revs. first it would restart but stall when in gear, then it wouldn't even start. I had replaced cap, sensor, rotor wares etc. we did have a problem after all the replacement getting spark. A friend mechanic (not sure what he did) but jumped the ignition module to wake it up and it ran well. took it on the water the next week, no issue, then took it out yesterday, ran no issue for about 30 mins. Anchored for about 30 mins, then heading home was when the issue started. I did have water in the tank, I thought I got rid of it, maybe not? Just not sure how to pinpoint the problem. Ignition module isn't cheap so I don't want to go there unless I need to. If it is water in the gas, I am also unsure how to completely drain the tank. HELP!
