Hello,
I am new to forum and have had my boat three years. It is a 1997 VIP Valiant with a 4.3lx gen+ thunderbolt 4 ignition. My boat as had the same issue the last year of when it get to operating temp 160-180 and under load it will start spark knocking at full throttle. You can back out of the throttle and maintain speed for a little while then it will start doing it again until you are down to no throttle and have to stop and shut the boat off and let it cool down. Also the manifold on the left(looking at front of engine) is significantly hotter the the one on the right. I always run 89 or 91 octane if available. I had a full tune up done on it last year new plugs, wires, cap, and rotor they also adjusted timing, cleaned carb and told me everything was set to Merc specs. I have had another mechanic look at it recently with out digging real deep he thinks it could be the ignition control module. But with a new one being so expensive im curious to know how to test this one. Or if anyone has any other opinions on what could be the cause of this issue.
Thank You
Thank You
