4.3 mercruiser steaming out of back of boat
jdelisle
I recently replaced both manifolds and riser and had the heads off to water infiltration.
when boat first starts there isn't any steam. The steam starts once the thermostat opens.
It was 48 degrees outside and raw.
I've updated post with picture.
alldodge
Re: 4.3 mercruiser steaming out of back of boat
Are you saying the engine starts and you have water coming out. After the time it takes for the engine to heat up and the thermostat you then see steam (maybe 15 to 30 minutes). What does 48 degrees outside and raw,,, mean
flipbro
Master Chief Petty Officer
It means its cold! Hot water and cold make steam
alldodge
Golly gee wiz and shucks and all other kinds of stuff Opie
jdelisle
It was 48 degrees outside air temperature and raw/damp day.
jdelisle
Please check out picture. Still normal?
alldodge
The steam doesn't bother me that much on a 48 degree day, but the lack of water coming out the exhaust vents does. I see a lot of water coming from the muffs. Loosing that much water around the muffs is either the impeller is not working properly or a new set of muffs may be needed.
Our my assumptions correct?
flipbro
Alldodge sorry that was ment for jdelisle not be a smartass with you lol! But stating TO HIM that at that temp and the hot water steam is normal!! This aint Mayberry
jdelisle
Alldodge I'm going to change the propeller this week to be on the safe side.
Flipbro, I guess you get your name for being flip. I started this thread to get help not to be poke fun at.
Pete104
It's pretty obvious in the pic that the pump ain't pulling much water. And, I can't see the tach from where I'm sitting either. Is the engine at idle or 1000 rpm or more?
Why are you changing the propeller? If you men impeller, put a complete kit in it!
Study some forums on replacing water pumps so you don't get yourself in trouble.
BRG25
What temperature is the engine running at when warm. How hot do the manifolds get?
jdelisle
yes I meant impeller te boat was idling at 800rpms
jdelisle
The engine temperature was 170 riser temp port side 119 and starboard side 88.
I ran the engine after that and there was onle a 10 degree difference between risers
jdelisle
replaced impeller which looked in good shape. Ran boat on trailer in the lake and everything runs great.
