4.3 Mercruiser won't start.
leafan69
I started my 1996 Campion with 4.3 (carburated) this spring-it ran fine with no issues. I then changed my leg oil including removing the reservoir and its contents and disconnected the leads attached to the reservoir. After finishing and reconnecting everything I tried to start the engine and got nothing. I raised the leg wondering if the battery was dead and it worked fine but after that i couldn't lower it or raise it again. I hooked up the jumper cables hoping again it was just a dead battery but to no avail. I don't even get a click when I turn the key.
Re: 4.3 Mercruiser won't start.
Ayuh,... The things you did have Nothing to do with the starting circuit...
Check the battery, then follow the Power...
