Serial Number: 0M011624 Model Number: 4211015N1 Outdrive Alpha1, Gen II
Previous owner was impeccable. I can eat off the block. When I went to pick it up, it was on the hard. With water to the muffs the engine fired up with the help of a bit of ether. Ran strong and temps were coming up as they should have. When owner hit Trailer switch on throttle, engine died. Hasn't re-started since, but will run on the ether.
1. Electric fuel pump and oil pressure sensor are both new.
2. Checked emergency cutoff at throttle assembly, even bypassed it. (I have a lanyard on order to go in it's place).
3. Fuel level is 50%. I do not know how old the fuel is but it ran strong till Trailer switch was hit.
4. Battery is strong. I've ordered new ground bus and will be replacing all ground wire terminals at the bus when it arrives.
5. Trim up, down, trailer up, and guages all work. All circuit breakers under column and in engine compartment are good.
Electric fuel pump was just installed as he thought that was the problem. I feel it is an electrical gremlin. My next step is to call in a priest and have an exorcism on it.
