4.3 MPI Injector fuse keeps blowing.
gbouldin
Need some help with this one. My starboard engine gave an injector fault this weekend. After reading this forum I found a blown fuse in the ECM fuse block. Tested the circuit with a multi-meter and found I had a dead short in the wiring harness. I have replaced the wires to the injectors, but I'm not sure what else is on that fuse. Any suggestions would be greatly appreciated.
gbouldin
Thanks for that tip, I'd read that one but didn't sound like they found the solution. I'm really having a problem finding a schematic that shows what is powered by each fuse. I was planning to just run new wires to each device to see if the problem stopped. Any other suggestions would be appreciated as well.
Bt Doctur
