4.3 OMC SLOW speeds
mohogg
Hey guys.... Need some help. I have recently rebuilt my rochester 2 bbl carb and set all the variances on my OMC 4.3L. The boat is a starcraft 18' bowrider and has a 15 x 17 prop on it. My question is what should I expect to see speed wise out of it. At WOT I am around 4700 - 4800 rpms can only get up to 30mph if I play with the trim. This is with just two people in the boat. I expected to see around 40 - 45 mph but was dissapointed. I tried a different prop (comprop) 13.5 X 22 and had even worse results. Around 23 mph and 3700 rpms. DO I need to look at the idle mixture on the carb? The motor runs great but the power doesn't seem right. Any help would be greatly appretiated.<br /><br /> :confused: :( :rolleyes:
Lark40
Re: 4.3 OMC SLOW speeds
Max rpm for that engine is 4400-4600. So, your under-pitched at 17".<br /><br />Try a 15 X 19 prop for your size boat.<br /><br />Use a GPS to determine speed, don't rely on an old water pressure meter to be accurate.<br /><br />I would agree that 45 is a reasonable top speed for an 18' boat.
karayj
I too have a 18ft seasprite 205 hp 4.3 4 bbl and I have a 13 1/2 23 pitch thats what mercruiser says i should have
karayj
check your timimg I played with mine last year and got more speed advancing the timeing..
mohogg
When you talk about advancing the timing are you saying by the distributor rotation or how? Also is there any chance that I have the idle speed adjustment screws set wrong I heard that preliminary sttings should be around 1.25 turns? I'll try the 19 pitch prop to see what it does.
Liquid_force
I have an '89 4.3 omc with a 2 barrel, but it's in a 19' sunbird. It has the recommended prop - 14.5x19 which I would say is in fair condition. I can get it to about 40 at 4200-4300 rpm's.
akriverrat
what did it do befor the work was done? idle mixture setting has little to do with wot rpms.
