4.3 OMC...
notinbig
I took my 88 larson 18 foot with the 4.3 omc. I feel like it sounds loud, like there is engine noise or a motor mount going badno louder when in gear or not so I don't think its the drive. But it runs like mad. any ideas????sugestions???? :confused:
Re: 4.3 OMC...
Your Discreption leaves a Lot to be Desired......<br />You give No Direction in which to Even Guess,<br />As to What your Problem Might be.(IF there is 1)...........<br /><br />Your Engine Sounds Real Quite From Here.......... :D
fireship1
Re: 4.3 OMC...
Hello, I'm not much of an OMC guy so I might not be right on with this question....but....did you check the obvious? Check your exhaust system carefully. When you say "it seems to run loud" I assume you mean exhaust. Your system might have exhaust bellows (if it's like a Merc :D ) check to see if it has any tears or rips. It is under the outdrive where it tilts. It would cause the engine to sound louder when running.
notinbig
Re: 4.3 OMC...
Sounds like lower engine noise but it resonates thru the fiberglas and that makes it very difficult to tell where it is coming from. I may just be paranoid, because i know what happens getting stranded. been there, done that, and helped others but ya know. sorry I can't be more specific, I will check the exhaust syatem though, thanks.
