Eric Bornstein
- Jul 24, 2015
- 14
I have read many of the posts on overheating. Last winter the Intake manifold froze as I did not drain it ever, now I know it does not drain completely with the engine drains. I have changed the exhaust manifolds and intake manifold this year. I changed the raw water pump a few years ago when it was overheating over 3000 rpm and cleaned out the risers and that seemed to work. This year I also had intermittent starting problems,cleaned all contacts and changed the distributor cap, coil and pickup module. Likely the module and it starts and runs well, also timing reset. I put a clear hose on the raw water feed to the power steering cooler and ran it into a bucket. Flow seems good and no bubbles. With the muffs on and 50 degree water feed, the exhaust manifolds and risers stay cold as does the big hose that leads to the circulation pump. I changed the thermostat (140 degree) It now holds temp until revved to 2000 and then slowly climbs to just bellow the red mark on the gauge and reads up to 225 with a temp gun at the base of the thermostat housing. Should I be looking at the circulation pump? Also is the slot next to the thermostat supposed to be covered by the gasket?
