Long term lurking as I’ve usually found my answer by searching.
Anyhow, I have a 1999 Chris Craft 190 Bowrider with a 4.3 Volvo Penta sx-m. Apparently, the previous owner had swapped in an early 90s 4.3 pre balance shaft engine. Engine had a cracked block and I replaced it. This turned into an ordeal because pre balanced shaft engine internals are compatible with the latter. I bought a 2003 Mercruiser 4.3 with a blown head gasket and rebuilt it.
Engine has been installed but need a little help with sensor connectors and sensors themselves. Looking at schematics, I’m missing the temp sensor which I think should go in the intake by cylinder 2 where I currently have a pipe plug. Not sure what the connector looks like. Also, the oil sensor and oil switch. I need there locations and what the connectors look like.
Any help would be appreciated. I do have the factory harness that I’m working with.
