Volphin
- Jun 5, 2011
- 1,405
Hi guys,
I have pulled my old 4.3L from my 19 foot Regal ('89) due to a faulty block. 11 years was a good run for it.
I have done some upgrades over the years, and here is where the engine is to date:
4.3L Normally aspirated, Non Balance Shaft, roller cam.
True Vortec Heads
1:6 Roller tips
1409 Carb with 1485 Cal kit.
2114 Eddy dual plane manifold
SeaKamp SK 4802 (for new engine)
I have a short block in a crate, awaiting installation, but would like to upgrade the cam for a greater, wider torque curve.
The cam in the shortblock is a Melling CCS-38 which remarkably matches the
'91-'93, ZR9/Z79, Syclone/Typhoon cam in specs:
- Lift (I/E) - .351/.386
- Dur @ .050 (I/E) - .179/.195 (.252/262 @ 0.06/rocker ratio)
- IC/LS 108/112
Comp Cams recommended these cams:
Cam 09-412-8
- Lift (I/E) - .334/.334
- Dur @ .050 (I/E) - .260/.266
- IC/LS 108/112
RPM: 1200-4500
Cam 09-415-8
- Dur @ .050 (I/E) - .266/.270
- IC/LS 108/112
RPM: 1800-5000
Which would you pick and why? Is there another alternative I'm overlooking?
Will probably want to upgrade the pistons as well. Looks like Sealed Power OE type units.
Any recommendations for a slightly higher compression upgrade?
Thanks!
True Vortec Heads
1:6 Roller tips
- IC/LS 108/112
Cam 09-412-8
- IC/LS 108/112
RPM: 1200-4500
Cam 09-415-8
- IC/LS 108/112
RPM: 1800-5000
Thanks!
