4.3L engine ID and year?
Caddy_Kid
I bought an '87 Sea Ray with a new to the boat 4.3L Vortec engine.
I would like to be able to get some numbers off of the engine and do my own research and see if I can corroborate the story and know for sure what the heck it is. That being said, I don't know where to find the numbers on the block that I need, nor how to read them when I do. On my 454 in the jet boat it was easy to find all of that, but this one seems to be a bit tougher. Any assistance would be greatly appreciated. Thanks!
thumpar
EFI was rare in boats until the 2000's. Even today the 3.0l can come with a carb if it is old stock. What exactly are you looking for? Without a Mercruiser serial number you might have to piece it together.
achris
More fish than mountain goat
Heads and block have a casting number, usually 8 digits. The block one is on the back of the flywheel housing flange, and the head numbers are under the valve covers. Once you have those numbers, just use the web-thing and do a search, plenty of good information. There is a site called hotsixes, that has the full history of the GM V6, including casting numbers and years. It's a good read, and very informative.
HTH,
Chris........
Caddy_Kid
My goal is to figure out the year of the engine and if possible what it is as far as a commercial/industrial engine, truck engine, car engine, etc. I know when I researched the block and head numbers on my 454 it was able to give me all of that good stuff, so I'm hoping I can get the same for this one, since I don't have first hand knowledge of the engines history and pedigree.
I'll have to check out the hotsixes site and see what I can get from it. With any luck the engine numbers wont be too buried, will try to get a look for them this week. Thanks!
I bought an '87 Sea Ray Pachanga 19 with a new to the boat 4.3L Vortec engine. The seller was a marine mechanic at a local boat shop that bought it on the cheap because it was missing the engine. Apparently he bought the engine in it now from a guy that was going to put it in a rock crawler (but never did) and he in turn got it out of a 2011 propane fueled forklift. Runs like a champ with no lifter noise or anything funny, so seems to be in decent shape. It is not fuel injected and does have 2-bbl carb, so the carb intake rather than EFI might make sense with the propane forklift story.
Ayuh,.... Have ya found Any ID tags, anywhere,..??
Any names on anything,..??
Post some pictures,....
Caddy_Kid
I just got home from work and checked it out and here is what I found at a glance:
On the Port side this is STAMPED into the block by the bell-housing:
4.3L 61911
Since its stamped rather than cast, I'm not sure if this is a date code or just another GM code.
On the Starboard side CAST into the block by the bell-housing is:
GM 4.3LG
12600234
It looks to me like I would need to remove the exhaust manifold to get the valve covers off to check the head numbers, but the valve-covers themselves do say VORTEC on them, for whatever that's worth.
When looking around, I did notice that the crank position sensor was on it, but with the wires cut. So perhaps it hasn't been a carbureted motor for all that long.
Caddy_Kid
Well nuts, guess it isn't a 2011. But at least it is still in the 2000's I guess. I did remove the oil fill and was able to see that it does have roller rocker heads, so that's a plus at least. Thanks!
