Tafflad
- Oct 23, 2007
- 544
I have a 1 yr old Maxum, with 4.3L carb Mercruiser.
Using standard 95 RON fuel
It has done 32hrs.
I have found that it frequently runs on when switched off ... sometimes for up to 20 sec. or more.
This is not on particulary hot days ... but it happens on them as well.
Boat is not being driven hard, and everything is as standard - incl the platinum plugs.
A bit of Googling - has found :
99% chance of it being Throttle butterfly not closing
Cooler running thermostat needed
Cooler plugs needed
99% chance Bad fuel
Idle speed too high
Mixture too rich
99% chance timing is out
Be interested to know where would be best place to start ?
Or as under warranty ... is this a warranty item, and I should just book it in ?
It has done 32hrs.
Cooler plugs needed
99% chance Bad fuel
Idle speed too high
Mixture too rich
