misterme21960
- Sep 16, 2009
- 13
Ha, I was fishing the other day boat was running fine...decided to float and fish so I turned the engine off with NO problems...fished for 30 minutes started the motor back up and it wouldn't go anywhere forward or backwards...and it does make a NON motor noise when the engine is running...not real bad but I can hear it...
With boat out of the water engine OFF, I put the boat in gear and can only turn prop one direction in either forward or reverse which I assume is right...and in neutral it spins freely...shift linkages seem to work properly never had a problem with this boat EVER and I take care of it...
Inside the Engine compartment you could eat off it, clean, and the boat is a 1988 Larson with a 4.3L Mercruiser and Alpha One Outdrive...This boat has never been beat on or misused and NO one has ever drove it but me...all the fluids are clean and fresh...all the cables that run the throttle and linkage were new 4 years ago...and until this year the boat has only been out maybe 10 times since 2008...
Funny thing is there was never even a sign of any problems until I started it up that last time...Engine would rev but wouldn't move in the water...Thinking it could be that coupler in the bell housing, but wouldn't the prop turn freely even if it was in gear, Engine off...if it was that coupler?...
Another idea of my own is where the cable attaches to the outdrive from the throttle, since the from what I see the linkage moves when I operate the throttle...Also thought the prop, so I took it off and gonna put on my spare in the morning...but I'm thinkin' if it was the prop it would still move just alittle bit in gear if the center was spinning...Any ideas so I don't have to take it to a shop, not only do I not trust any shops...But I don't believe in what they charge to work on anything for the quality of work, I can do it myself with online and book knowledge...It isn't that difficult...and I can do about anything...And these boat forums are awesome, I would love to hear any ideas and if I'm heading in the right direction with this before I put the boat up this winter
