sterkelfamily
- Sep 26, 2015
- 6
Today I changed the oil in my 2003 Crownline 180BW It has the 4.3L MPI engine. The oil filter is remote mounted from factory. I pocked hole in top of filter. Let sit for 1 hour. Removed oil and installed new AC Delco oil filter. Vacuum pulled the oil from engine out the dip stick tube. Added the correct amount of oil that the local dealer said to. Started engine and no oil pressure. Let run for 15 seconds. Pulled filter and no oil in filter. Reinstalled filter and ran for 20 seconds off idle. Shut off and pulled filter. No oil. Had oil pressure before changing to warm it up. Removed filter and started engine without filter and no oil from tubes. What am I missing.
Please help
Background is I am a GM tech of 25 years. This style engine in a car or truck only takes less than 10 seconds to get pressure.
Please help
