4.3l mpi new sqeek
tpenfield
no squeak . . . a rattle sort of noise though . . . Use a tube or mechanic's stethoscope to isolate where it is coming from.
tpenfield
Have the Mods merge your 2 threads. Not supposed to do duplicate posts.
Here is my comment from the other thread.
"no squeak . . . a rattle sort of noise though . . . Use a tube or mechanic's stethoscope to isolate where it is coming from."
Furbird
Turkey in the bilge? JK. Sounds like an idler/tensioner pulley bearing personally (if it has a serpentine system).
baconfudge
im on boat on phone sorry about misposting, it has a serpentine belt wth 5 pulleys
Furbird
The only way to diagnose it is with a mechanics stethoscope. That is an actual tool, but you can redneck it by using a long screwdriver and pressing the handle up against your ear and the tip on each individual component (alternator, power steering pump, water pump, tensioner pulley, idler pulley.) The noise will come through the shaft of the screwdriver so you can hear it. Harbor Freight sells the actual tool but I don't know anybody that has one as most everybody uses the screwdriver method. Pry bar/long extension/basically anything solid and long enough to reach each component will work. I've seen people use a wooden broom handle.
