4.3l starting
tkwbigtwill
engine only fires just as i release key.It idles fine and runs great.I can let it crank over 10 times or 2 times but it only fires as i release key.Help please.
McKenzie
Re: 4.3l starting
My first guess is the igntion switch, do both terminals get juice when you turn the key to the start position? Does this engine have a ballast resistor? A wire should be run from the starter solenoid to the positive ignition coil terminal. I don't think that is the likely cuplrit, but its worth trying.
tkwbigtwill
Re: 4.3l starting
I'm not sure if it has a ballast resistor I'll have to check.Where would it be located?----1988 four winns 200 horizon 4.3l
McKenzie
Re: 4.3l starting
Now that I think of it, you probably have a resistive wire instead of a ballast resistor(same difference). I don't think that is the problem though, what could be a cause is a bad igntion switch. even if it is the ignition switch, it shouldnt do that if a wire is run from the starter solenoid to the pos ignition coil terminal. Check to see if the ignition coil gets 12v when cranking. When the engine is running, the ignition coil should be getting around 8 or 9v. Tell us what you find
tkwbigtwill
Re: 4.3l starting
It's an OMC. I'm leaving for the lake right now to check it out. Thanks!
tkwbigtwill
Re: 4.3l starting
I replaced switch but still have problem. I put a volt meter on positive terminal of coil and when I cranked starter I only had 5 volts as i released key it started and voltage went to 9.75.I then put the meter on the purple/bk wire post on the starter solenoid with the same results.I have 12 volts on the yellow/red wire at solenoid can I put them on the same post? Is there a set of contacts inside of solenoid that closes to put 12 volts on purple/bk wire to coil?
McKenzie
Re: 4.3l starting
It sounds like a bad solenoid. You could replace it, or you could move the purple/black wire to another spot in the starting circuit. If you did that you might have to put a diode on the wire to keep the ignition coil from supplying power to the starter circuit.
tkwbigtwill
Re: 4.3l starting
Thanks,McKenzie for your help.Is there a difference between auto and marine solenoids.
