4.5 Mercury 2 stroke-
chimo665
Removal and rebuild kit for barberator 2 stroke older 4.5 . Any tips or shortcuts for novice ?
ThomW
Don't take short cuts. I'm assuming you meant carburetor rebuild?
Take your time. Soak the parts in carb cleaner. Especially with a small motor like that, the holes in jets are tiny and doesn't take much to clog them or cause it to run rough. Don't just take it apart, spray some carb cleaner in there, and say you're done.
As far as a kit goes, can't help you without a serial number or other info on your motor.
Everybody picks on the carburetor for some reason.-------What is your motor doing / not doing ?-----What trouble shooting has been done if any ?
