4 Bladed Prop Expectations
SNye45
It's going to be a long time until I can get on the water to test this change- It snowed this morning.
But I am eager to hear about the changes to my boats performance
My engine is a 2007 Suzuki DF115, Boat is a 20ft Aluminum.
Until now I have been using a 3 bladed prop with a 19" pitch. My next door neighbor who had the same engine recently upgraded to a Suzuki 150 and offered me his 4 bladed prop (same pitch)for a good deal, which I accepted.
My current results with the 3 bladed prop are: Top speed = 36mph WOT @ 5800rpm
Best Cruise = 25mph @ 4000rpm.
Can anyone please help me with some numbers than I can expect from the 4 bladed prop.
Thank you
aussiejake
Re: 4 Bladed Prop Expectations
Expect to lose around 400rpm at WOT with a 4 blade the same pitch as your 3 blade.
I lost 500rpm from a Mirageplus 17p to a Stiletto Bay pro III 17p.
tpenfield
Thank you
My guess is going to be 33 mph @ 5300 rpm, cruise at 22 mph 3700 rpm, better cruise lower top end
Hopefully you will get a chance to try it out soon.
steelespike
Your slip is near the high end of normal 10%.Is your speed by gps?
If the 4 blade can lower slip to 6% and you end up at
5500 my calculations indicate 35, speed could be a wash.
Can't be too specific but usually the 4 blade will stay on plane easier at reduced throttle,have better hole shot
and should handle better around the dock.
