Hi guys....<br /><br />Posted a couple days ago about my 4 Hp Evinrude, model # 4806E, 1978.<br /><br />Regapped the plugs to .03 from the old .05 and still plan to do a decarb this weekend.<br /><br />Put the engine in a large garbage can and ran it this evening...<br /><br />Changing the spark gap helped a lot and it seems to start more reliably under various conditions now....<br /><br />However, I got to wondering how well the water pump/cooling was going...<br /><br />With ALL the churning and foaming in the water....I could not tell at all where the cooling water comes out or even IF any was...<br /><br />Were is the cooling water exit on this little motor?<br /><br /><br />Then, I got to touching various parts of the engine with my finger.<br /><br />The "head" (the metal plate that the spark plugs screw in) was very hot to the touch, anything more than a momentary touch started a burn...<br /><br />On most places on the the "block" itself, I could keep a finger on for a few seconds, and some spots a lot more than that....<br /><br />Except for one place. Looking at the engine from the rear direction (so that you see the head and spark plugs), there is a roughly 3 inch by 5 inch thin flat metal plate bolted to the left side of the block....now that plate was hot as all get out as well....<br /><br />Does this sound normal/reasonable?<br /><br />Oh yeah, does this little motor even have a thermostat?<br /><br />take care<br /><br />Blll
