4 prong starter replacing a 3 prong help
rmcduffie70
Please help I ordered a replacement starter, my old starter has 3 prongs my new starter has 4. I have done out of boat test and the new starter works, old one doesn't but when I wire it up in boat it doesn't do a thing. Is there something I would have to jump?
Don S
Re: 4 prong starter replacing a 3 prong help
Those prongs are called terminals. 4 is normal for a marine engine. 3 if an automotive (cheap and dangerous in a boat) replacement. Plus, depending on what engine you have may help it start. Automotive is also an explosion hazard.
How to Ask a Question .... Please Read This Before Posting A Question...
rmcduffie70
Well the boat had a 3 terminal and it was marine grade, I am putting in a 4 terminal however it does not spin, it's a 1992 mercruiser 5.0L
rmcduffie70
I'm 100 percent positive the 3 term was the original starter, shows 3 term in the wiring guide that came with the boat shows 3 terminal, I am hoping that I can replace it with this 4 terminal which also is a rent marine grade that was supposed to be a replacement however the terminal number is different
Don S
There is nothing wrong with a 4 terminal starter. Just make sure it's marine rated.
rmcduffie70
Should it be wired the same way as the 3? Or do I need some kind of jumper because if I wore it the same as the 3 I'm not getting anything but a click from the slave solenoid
Don S
Just pretend the 4th terminal isn't there, and wire it up like your 3 terminal starter was wired. Nothing on that 4th terminal.
rmcduffie70
Ok does the starter have to be installed in order to be grounded or should it spin if I wire it up and not install it?
