Re: 4-stroke outboard oil article
I will do my best at summarizing the article:<br /><br />The chief comparison was between marine grade and automotive grade oils. As can be expected automotive oil is priced nominally compared to that of higher priced marine grade oil from major outboard manufacturers. <br /><br />I liked the illustration of driving a car around doing 2500 RPMS at 70mph vs an outboard or sterndrive 3500 RPM's or higher for extended periods of time. With this comparison, motor wear and tear is equivelant to going about 100mph in a car. For most recommended outboard oil changes at 100 hr intervals this equates to about 10,000 miles in an automobile which would be considered by many to be irresponsible maintenance. <br /><br />The article further noted how important changing oil more than recommended in a 4 stroke is imperative. The main claim is that 4 stroke parts are more susceptable to corrosion than two strokes. This is because two strokes leave an oil film on moving parts after the motor is shut down whereas 4 strokes don't. Further compelling reasons is what they termed "fuel dilution" as the motor is run at or near idle for extended periods of time (such as trolling) It was suggested fuel dilution lowers the oil viscocity to reduce protection which oil inherently provides the engine. <br /> <br />The top pick actually ended up to be Pennzoil 10W/30 automotive oil providing the regular recommended changes were followed. Other contenders listed from best to worst for corrosion protection as per Trailer Boats test were; Evinrude Synthetic Blend, Mobil One, Pennzoil, Mercury, Sierra, Castrol GTX, and Yamaha 4-M. The jury is still out as far as using synthetic oils for four stroke outboards but the article suggests Mobile one may be a good choice when/if manufacturers approve the use of synthetic oils in their outboard motors.<br /><br />Regardless of wheather you feel comfortable using automotive oil or insist on a marine grade oil, the most important consideration in terms of engine longevity is to change oil more frequently than the maximum recommended interval. In the long run oil is cheap but repairs are expensive.<br /><br />The article was about 4 pages long with a lot of info on oil chemistry but I summarized what interesting concepts seemed to stick out the most.<br /><br />Kevin
