Hi guys,<br /><br />I need some advise on the correct prop to choose for my boat. Here's the situation:<br /><br />21' daycruiser, 120 HP inboard Mercruiser diesel, Alpha drive, about 2650 lbs dry weight, V-hull, and now also with Smart Tabs that work great. The boat generally handles well and planes easily.<br /><br />The boat came with a 23" Black Max alu three-blade propeller, and did about 36 knot at WOT of about 4200-4300. Slip was about 13%.<br /><br />I switched to a 21" Ballistic steel propeller, and it now does about 34,5 knots at WOT of 4500, which is the highest the engine will go. The slip calculates to about 8-9%.<br /><br />The rated RPM is 4400.<br /><br />Now, the Ballistic doesn't like to be trimmed out much and will soon ventilate. In other words, apart from a better holeshot and a smoother ride, this prop change didn't do me much good.<br /><br />Also, I bought the prop online from the US, and with no return possible. I better hit it right the next time.<br /><br />So, before I blow any more money on this, I need some expert advise from you. Please pipe in.<br /><br />A good hole-shot, a good grip in the small chop, and a comfortable ride is what I am after. We rarely go at WOT, so top end speed is less of a priority, but it probably shouldn't go down any more. Finally, it is a diesel that is quite noisy, so if we could reduce rpm's somewhat without losing speed, that might be good.<br /><br />First of all, which brand and model of steel prop do you think will give the best allround performance without blowing my budget? Stiletto, Turbo, Rapture, Vengeance, others?<br /><br />Secondly, 3 blades or 4?<br /><br />Finally, which pitch should I choose. Back to 23"? What if I go with a 4 blade, does that affect the pitch as well?<br /><br />As you can tell, any qualified input would be appreciated.
