4 Winns 5.8L Alternator belt breaking
sgb
My 1994 4 Winns Horizon 210 with 5.8EFI, OMC Cobra outdrive, has been burning up alternator belts since I bought it a few years back. During acceleration, the belt squeals(it is slipping on the alternator pulley)and this slipping eventually burns and breaks the belt. The alternator checks fine at an alternator shop. I changed the alternator pulley with no luck. I put in a new alternator and it worked for about a year, but the problem has just recently started again. It only seems to do this in gear under acceleration and not just revving the engine in nuetral.
denniz
Re: 4 Winns 5.8L Alternator belt breaking
rust on pulley or bad front bearing.............
bernieb
Not sure on your set-up but can you go with a double pully using two belts or maybe if your alternator is already pulled to the extreme try a size smaller .You may look at the "green belts" but it's only a guess as they are a heavy duty belt.
akriverrat
there should not be a heavier load on the alternator at rest or accelerating. but is there? have you noticed on the amp and/or volt gauge any extra load when you're accelerating?
