40 force impellor
diegojones
Reinstalled lower unit on 97 force 40 after overhual. Impeller was fine now not working at all. How does impeller need to look or be installed correctly if no problems?!
12Footer
Re: 40 force impellor
Impellers allways look perfect until they fly appart. I'm not being cynical (heck, I probably even misspelled the word), but they truely do. If anything, there will be a slight bit of wear on the tips of the vanes, but will still function for a little while.<br />Also, an impeller that has been in a motor that sat for a few months without use, will "take a set". This is when the vanes form a shape to the eliptical pump housing, effectively ruining it.Impellers that have taken a set, will usually only pump water at high RPM. But as far as being able to determine the condition of an existing impeller, that's about it.<br />Regardless of how good an impeller looks allways replace it, and the thermostat, with new ones.<br />They rarely last longer than two seasons under normal useage anyhow, and less than that if you do a lot of idling.<br />Also, the thermostat will take about two minutes to open letting anything to show from the exaust.
eurolarva
When you reinstalled the impeller did you remember to insert the key. If not the impeller will not spin with the drive shaft
