40 HP '98 Force - Fuel Pump Rebuild?
njm_T160
Greetings All,
I have a 1998 40HP Force/Tracker on my pontoon boat. I'd like to rebuild the fuel pump but have never done it. Looking for any tips or "gotchas" to use or avoid -as the case may be. Any suggestions would be much appreciated.
Thanks,
Nels
Frank Acampora
Re: 40 HP '98 Force - Fuel Pump Rebuild?
Mercury fuel pump--dirt simple--a first for Merc-- Nothing special. The rebuild kit comes with all the parts plus extras for different pumps AND instructions. Should take you all of 15 minutes--oh, OK---25 minutes if you have never done it before.
Just take a photo before starting because it is possible to install the pump 180 degrees off.
njm_T160
Thanks for the tip, Frank!!
-Nels
jerryjerry05
Just make sure you don't bend the little pieces of plastic or plastic washers.J
