40 hp Mariner gear synchronising
scolew325
I have a 1970 40 hp Mariner and can not get the forward and reverse gears synchronised with motor. I can not find a repair manual anywhere. I did find a manual for 1976 to 1989 but shows nothing on how to get the gears right unless I'm missing something. I need some help please.
Texasmark
Re: 40 hp Mariner gear synchronising
What do you mean won't synchronize? Explain what you think is not happening.
Mark
scolew325
when going into reverse, the motor revs up like it should but the gears grind. Today I did see that a nut down low on the linkage did not have the locknut tight against the other. Maybe thats my problem, we'll see tomorrow. Before the boat was parked 2 years ago after the coils went dead on me, it did not do this but now it does. So don't know why. I got a repair manual and it says nothing on how to adjust the linkage.
Texasmark
So, am I hearing that your linkage isn't adjusted properly and when you select R the shift shuttle doesn't move back as far as it should and the gears are banging their tips against one another?
Mark
