40 hp no start weak spark... Bad power pack or stator???
Gastumpjumper
1995 force 40hp Compression 120 psi both cyl New fuel lines and filter Rebuilt fuel pump Clean carb Gets fuel ( spark plugs wet) New spark plugs Motor died after running fine and discovered bad fuel pump diaphragm ... Rebuilt and new lines then clean carb and set back to previous settings. Motor will not even hit at all even tried fresh premium gas. Will spark against block from plugs but not at all from tester and flywheel key is in great shape so timing is good.... I'm lost and need help
