40 hp only going 1/4 speed when wide open
Biggen
I have a 40 hp tracker motor, made by mercury, One day it started idleing very low and cutting off when i tried to engage it into gear. Once i got it into gear it only went about 1/4 of the speed it usually does. In neutral it seemed to rev fine, but when in gear, the rpms werent high at all. I looked at the carb thinking it wasnt opening all the w2ay, but it did when the boat was on gear at Wide open throttle. Any suggestions? Fouled plug? Thanks
RICKRICK1
Ensign
Re: 40 hp only going 1/4 speed when wide open
Check cylinder compression. Check for spark, check fuel system for sucking air. Overhaul carbs.
Biggen
Do those problems you have listed come overnight or do they gradually get worse, I was hoping since it happened all of a sudden it would probably be something less severe than loss of cylinder comp or a fule pump problem.?
Biggen
would a cylinder lose compression all of a sudden or would it be gradual. Im guessing at this point it may be a head gasket, i cleaned the plugs and it still isnt running right.
The Marine Doctor
Biggen..you engine does not have a head.<br /><br />Yes it is possible that the engine lost compression immediately.<br /><br />TMD
