Greatlakesfisherman
- Feb 25, 2009
- 16
I have a 1985 Johnson 40 HP Model J40 RL COB- Runs on top cylinder only. Bottom cylinder spark plug looks wet but does not seem to be firing. Tried switching the coil wires around with no luck but not sure if I did it correctly. I also looked for any spark and could not see spark from either plug- even though motor does run on one cylinder. Compression is about 105 in each cylinder. Tried new plugs but still would not fire bottom cylinder.
Due to the wet bottom cylinder plug I think I am getting fuel to the cylinder through the carburetor but it is not firing so?I?m guessing that I have --A) a bad coil or-- B) a bad power pack.
Any help would be great to point me in the right direction.
