Re: 40hp evinrude wont stay running
I would do as Roscoe suggests and rebuild the carbs and fuel pump. Compression can be checked cold, as all you are looking for is the cylinders to be within 10% of each other, regardless of the readings. I'm betting clogged carbs, as it did run well last season... FYI, it is not nessesary to drain the carbs at the end of the season. Just add stabil and keep um full.
