Hello, Any help would greatly be appreciated. I have a 1991 Johnson 40hp that I just purchased for my retirement fishing boat. I eliminated the VRO and replaced with new Vacuum pump. Replaced all fuel lines. Rebuilt Carburetors. New water pump. New plugs. New filter. Carburetors looked very clean inside with no corrosion. Cleaned them very well and all passages were cleaned and kit installed. New Primer kit installed. Engine will start and Idle for 5 to 10 seconds and die. Can keep running if bump the Primer. Has 145 and 150 compression. Primer ball pumps up and gets hard. Does not help to use primer ball to keep running. I have went back thru all my work and cannot find what is wrong. Any ideas? I am ready to go fishing and start my retirement finally.
Thanks Jeff
Thanks Jeff
