SierraMark
- Feb 27, 2012
- 135
I am trying to replace my trim motor on my 1991 Mercury 40 oil injected motor.
I cannot get the dowel out of the bottom rod as described in the manual so my plan B was to remove the 3 nuts and bolts on the starboard side of the motor and the 3 bolts that are on the port side of the motor.
I started by taking off one nut and bolt from the starboard side and I realized that with the trim motor/reservoir the bolt would not come out so I looked at the port side and saw that there were only bolts.
I figured if I take those bolts off and remove the nuts on the other side I would be able to slide off that entire trim unit.
I tried one port side bolt and it was stuck solid. I went to the next one and it started turning then it snapped off in my hand.
At this point I am completely bummed and thinking that maybe my delusions of repairing and soon rebuilding my boat might just be beyond my ability but I am hoping that is not the case.
So, I spoke with my auto mechanic brother and he said to drill it out and if need be we can put a helicoil in there and no problem.
My questions to you are:
1. does that sound like a good plan?
2. Is my assumption that I can get the trim unit off in this manner a correct one?
3. should I just throw all the pieces/parts into the boat and haul it off to the marina where they will undoubtedly have no issue replacing all these parts with shine new expensive ones?
Thanks,
Mark
Thanks,
Mark
