40hp mariner oem prop?
Dukhunter925
i boat a 1986 bass tracker (aluminum) with a 1985 40HP mariner. The prop was jacked up pretty bad. the only lettering on the prop is propco 14p.
i was wonder what the diameter of an original was? as well would you all suggest the same diameter and pitch?
i will be using it for duck hunting and fishing. so i would like good low end without taking to much away from the high end.
any suggestions would be great
thanks alot,
Zachary
Silvertip
Re: 40hp mariner oem prop?
Measure it. One blade tip to the exact center of the prop shaft then multiply by 2 = diameter.
buddyearl
I have the same prop. It measures 10" in diameter. What does the 14P mean, it's pitch?
