jakers4777
- Jan 11, 2003
- 12
I've had to disconnect the VRO on my '89 40hp Johnson.(bad oil pump, lack of cash to replace it).<br /> I've seen several posts here about the wiring of the pump and none matches mine.<br /> My boat was rigged(new) by Tracker and several pieces and parts are not standard Johnson.<br /> The 3 wires from the pump are routed under the powerhead and I cannot find any quick disconnect anywhere on the harness, in fact, after the wires disappear under the engine I can't even find the same colored wires at the terminal box.<br /> I've cut and taped the 3 wires coming from the pump and cut and taped the 2 wires at the top on the oil tank, removed the VRO pump, installed a new standard fuel pump and put a brass plug in the pulse limiter hole in the block.<br /> I've cleaned the carbs and put in carb kits and all new fuel hoses.<br /> Running fine on the muff and hose but I'm wondering if I'm missing anything on the VRO disconnect that may hurt the engine.<br /> Too cold here to try it out on the water right now. Just wondering what I may have missed and want to get it right.
