45 HP Mercury, won't shift right, please help
boatsalotjay
I dropped the lower unit out of a 1958 45hp mercury to change a grommet, and now when I tried to put it back on I couldn't get it to drop out of gear. It will shift at the shifter but it won't go into neutral, or forward for that matter. thanks
corm
Re: 45 HP Mercury, won't shift right, please help
your lower shift shaft is probably about 180degrees out. Anyway turn it untill u get a N then let it drop into F and install. Make sure the upper shifter is in F also.
boatsalotjay
thanks Corm, I'll try it.
