45 Mariner Tach Hookup
KevinTee
I have a 1988 45 HP Mariner. Two Tach related quetions.<br /><br />1. Do I need a special tach for setting idle and checking max rpm?<br /><br />2. What color wire at the controll lever will I hook up to?<br /><br />I have a service manual but it is kind of vague as to what kind of tach and where to hook up.<br /><br />I used an automotive tach and it seamed to work fine for idle but I am either over reving at WOT (a lot) or the Tach was not working.
Laddies
Banned
Re: 45 Mariner Tach Hookup
the tach on that engine is driven by the 12 pole alt. and you can't use a ign. driven tach like most auto tachs are
KevinTee
Thanks for the reply the manual does not show that.<br /><br />So if I install a tach would I set the selector on the back of the tach to 12?
KevinTee
Did not want to be like the guy with the Tilt/Trim problem and not reply.<br /><br />Purchased and hooked up a regular boat tack. Works great. Timing and Sync compleated. Engine tachs out at 5800 WOT should be 5000-5500. Going to leave it alone and cruse at 5000.<br /><br />Thanks for the help.
