CayugaCobalt
- May 6, 2008
- 138
on the other side ????????????????????????????.maybe.Ayuh,..... Where's the other one is the question,..>>
Oh ya,..... Alitte blurry this mornin,....on the other side ????????????????????????????.maybe.
Thanks Dubs: That is the answer I was kinda expecting but wasnt sure.Rear engine mount bolt
Yes, due to the spacer
If it's tight, it's tight
You should tie the sender wires out of the way as not to interfere with the steering actuator nor rub on the coupler
yes on the other side; not in focus but visibleon the other side ????????????????????????????.maybe.
No worries BondoOh ya,..... Alitte blurry this mornin,....![]()
How often or when is one supposed to do the alignment check? What are the symptoms of mis-alignment? The bushings I see around the bolts are standing up, not collapsed. Sorry I dont see whay bushings you refer to.When was the last time the alignment was checked?
Those rear mounts look like the bushings collapsed
